bravia kdl-32u3000 hd/3D compatibility
jazirat3
Does anyone know if a Sony bravia kdl-32u3000 has hd or 3D compatibility? And if so, what is required in addition(if anything) to the basic TV? Many thanks in advance.
etritd
It has not 3D compatibility. But it has hd compatibility and all you need is a hd signal:
1. from your cable provider via a hd set-top box or hooked up directly in ur tv
2. from satellite via a hd satellite receiver
3. you can watch the freeview hd channels available in your area
etritd
