Bright or dark flash between scenes - KD65X7053
mousetarget
Just bought a KD65X7053 - sometimes I'm getting a less than a second flash between scenes, sometimes its white and sometimes black, depending on the contrast between the scenes - its very annoying - can anyone help?
mousetarget
I've sorted this - so if anyone else has the same problem you need to go into the picture - advanced settings and turn off the Advanced Contrast Enhancer - hope this helps others
