Can anyone explain why I am unable to unzip the pkg4.077eul-0108 download?
errobin75
Any suggestions?
sonytjm
If it is any consolation it worked for me on Windows XP. You do not say what happened.  I think the unzipped file needs to be in the correct named folder to work - but I could try attaching the resulting bin file if you think it would help.
