can i conect to the internet sony KDL46NX723?
profile.country.en_IE.title
ilonasaule
Hi there
1 - Press the blue HOME button on the remote control.
2 - Scroll across using the arrows on the remote control until you find "Applications".
3 - Scroll up and you should find "Internet Browser" and press OK on the remote control.
4 - Once on the inbuilt web browser, press the OPTIONS button on the remote control.
5 - Scroll down to "URL entry" and press OK on the remote control.
6 - Delete the web address in the box displayed by either pressing the GREEN button on the remote control repeatedly, or by highlighting the CLEAR button on the onscreen keyboard.
7 - Type in the required web address on the onscreen keyboard.
8 - Once done, highlight the "Enter" button on the onscreen keyboard, and press the OK button on the remote control.
As a personal opinion, I found the whole web-browser experience via the TV rather difficult and cumbersome. Once you have set a few bookmarks, it does get easier. And you do get quicker doing everything via the remote control over time. I always remind myself that its a TV and not a computer.
Hope that helps you.
4 REPLIES 4
Hi there
Yes, the NX723 TV has an inbuilt network port (NIC) as well as Wireless is already built in. You can use either.
Cheers.
ilonasaule
thanks i already conect by cable but cant find where to type google? just watching videos whats built in tv.dont know where to find google.com showing just sony.com/support site?could you text me how to do or find it ?thanks:smileywink:
Hi there
ilonasaule
thanks it work for me
