My wife went to visit our daughter and her husband and they have just bought a new TV and have also got a new soundbar fitted.
Now having a soundbar in action she would like one.Our TV is a Sony KDL-42W653A and I would like to know if I can fit a soundbar to it and if so how do I do it any help appreciated.
Have found the following would I be able to connect this to the HDMI 2 Port.
https://www.amazon.co.uk/Neoteck-Splitter-Splitters-Amplifier-Projector/dp/B01GHFJL10
Have just realised that this one does not switch as I wanted one with the remote to save getting up and changing manually.
@muffin1947 wrote:Have just realised that this one does not switch as I wanted one with the remote to save getting up and changing manually.
Hi @muffin1947. Sorry you are on your own with this one. You certainly need a switch and not a splitter that has 1 input and 4 outputs. You need 4 inputs and 1 output.
Just a matter of finding one my three way hub is made by Neet and have used Neet producs before so will look at what they have.Thanks for all the help.
The following item looks good to me hust wondered what you thought and not too expensive.
My wife has decided it would be nice to have a soundbar since we visited our son and she saw his new TV and Sound Bar.I went to Currys PC World yesterday but there are so many and so confusing.I would be happy to pay about £100 but not sure of the set up procedure.Some said bluetooth some said wireless but the salesman suggested that using a optical cable was best.I did read that it was better to connect them using a HDMI lead plugged into the HDMI 1 socket on the TV and into the HDMI socket on the sound bar.My HDMI socket is marked up as (ARC 1 ).The TV is a Sony KDL-42W653A.Would it just be a question of plugging in the HDMI lead and it would be ready to go.Thanks
