Can't access Internet Browser on Bravia TV
quarte
I have a new Bravia. When i try to access the Web through the Applications Menu, Internet Browser it takes me to a "choose Country" page and after selecting UK, to the Sony UK Website.. I can't get further than this. Is there a way to access a web browser.
2 ACCEPTED SOLUTIONS
quarte
problem solved by going to Options and selecting 'enter url' .. everything working fine now, though a lot slower than pc or laptop..
Hi there
Unfortunately I cannot give you full step by step instructions as I dont have a 2014 TV, but should be reasonably close.
  1. Load up the web browser as per the FAQ instructions : HERE
  2. Press the [Options] button on the remote control, and the following menu should appear:
  3. Scroll down to "URL Entry" on the menu and press [OK] on the remote control.
  4. Use the on-screen keyboard and type in the web address (ie http://www.google.co.uk)
  5. When done, highlight the [Enter] button on the on-screen keyboard, and press the [OK] button on the remote control.
Hope this helps.
33 REPLIES 33
quarte
New_technology
:smileyconfused:I also have same problem with my new sony bravia TV, (Sony web page preventing me for accessing the web browser) my tv model is KDL-26EX320, but when I choose 'Options' the 'Url' choice is not listed.  Can anyone suggest an alternative solution?
tigers50
on the sony kdl bravia i cant access internet browser it come up as file not found with blank screen any help please
tigers50
i go on to the app browser it comes up saying file not found
spiegelmaestro
I have a Bravia TV (Sony Bravia KDL- 24EX320). I want to access the web. I go through the process and get the Google search page up by inserting the Google URL and achoieve the Google search page. However  how do I then get into the Google search line in order to type in a search the internet.
Cheers DB
Hi there
Thats the difficult part.  You need to use your remote controls arrow buttons (up/down/left/right) to basically give focus or highlight the search text box.  Once done, just click the OK button on the remote control and an on-screen keyboard will be displayed.
spiegelmaestro
I can get the google search text box but when I highlight it and press OK, nothing happens. The on screen keyboard input box does not appear. Could it be that Google is the wrong search engine to use? DB
Your model is a 2011 TV, I also have a 2011 TV, and google works just fine on the TV, so....
Try going to a website that has another text input box and test to see if the onscreen keyboard works.  If it doesnt, I think a factory reset of the TV is required - as I vaguely remember that this resoved someone elses problem.
gopi57
