catch up not working
BarbW52
Catch up not working yet again on Sony Bravia TV...get half way through programme, that's when we have finally managed to get the app to work only for it to freeze then stop working .Id have been better buying a cheapTV from Aldi or Lidl not a £500.00 Sony !!
Joe_Dohn
Specialist
It would probably help to make sure you have the latest software installed on your TV and getting the latest version of the app as well. I believe the option is called Refresh Internet Content and is under the Set-up - Network settings page.
8 REPLIES 8
Sean_Mc
Moderator
Hi there,
Can you let me know the full model number of your BRAVIA TV?
Best wishes,
Sean
BarbW52
Hi Sean, the model number is KDL-43WF660
Many Thanks for the reply
Joe_Dohn
Specialist
RGBodies
Joe I have the same problem and have done what you suggested but still can't get catchup for the last 7 days. Program guide for the future 7 days works fine.
dorothysony
Kdl49xg7073
Win_88
Specialist
Hi @dorothysony
Are you facing the same issue? If so, have you tried the designated solution?
Win_88
dorothysony
Tried checking WiFi and reconnecting .No better final got some apps to work but not my five !  by inserting Arial direct to TV .All apps available on Panasonic DVD do why not on Sony ?
Win_88
Specialist
Hi @dorothysony
it's really up the developer to make a certain app available on a certain device. Catch up TV is a combination of the aerial and internet connection so tuning the channels (at least once) is required. You can then remove the antenna from the TV if you wish.
Win_88
