Hello,
I would like to find out what is the maximum length Ethernet cable for bravia TV? Thanks
Solved! Go to Solution.
My understanding is the generally accepted max is 100m without the need for a powered switch or repeater. This is not a Sony limitation, more a standards limitiation though
http://www.wirelessforums.org/alt-comp-hardware/maximum-ethernet-distance-10531.html
Hope this helps
Hope this helps
