Connecting Xbox to sony bravia 26T2800 in HDMI
Rosc99
I have tried and tried.....how the hell do I do it. I have a picture , games are playing fine.....but not in HD...or...if that is the quality of the HD , it's rubbish
I am sure there is something not right
any suggustions would be welcome
Thanks all
Hi there
I wouldnt worry about the HDMI device list, as this is generally for compatible devices that supports Control for HDMI.  But in Settings under HDMI Setup, ensure that HDMI Control is switched on.
In regards to your original problem about HD.  This TV supports either 1080i or 720p so ensure in the settings of the Xbox that you are outputting at least on of those.
In regards to any picture settings, there is very little to experiment with, but look under the Picture Adjustment Menu.
See the TV's manual : HERE
To be honest, its hard to advise you, because there is very little settings on the TV that you can adjust.  You must also bare in mind that this TV is approx 7 years old now.
I hope there is something in this to help you at least.
5 REPLIES 5
Hi there
You will need to check the settings on the Xbox.
See Xbox Support Forums:
http://forums.xbox.com/xbox_forums/xbox_support/default.aspx
Rosc99
I was on to Xbox support yesterday....them say it is a TV problem....I agree the HDMI works fine on my other TV.
I am not the best at this kind of stuff...so it could just be a simple setting thats wrong.
When I go into device list on the Sony menu...nothing....like it is not reconised
Hi there
Rosc99
thanks for your help
Sapper024
Unable to find hdmi in settings options
