Daily Ring Tone Call on KDL-46EX723
AndyS007
My TV seems to start ring with an incoming call tine at 10:45 every day. I have disconnected from the network, it stills does it. I have removed all my widgets and it still does it. Any ideas what to do next?
Andy
AndyS007
Hi, Tried that, complete factory reset. This morning at 10:45 chiming call started again. Then I thought could it be something connected to the TV. Lo and behold my Sonos Sound bar had an alarm, now removed!
Thanks for your help
Andy
5 REPLIES 5
Hi there
This is probably the Skype app on the TV.  Try signing out of your account and see how it goes.
I would also suggest signing into your Skype account on a PC/Laptop and have a look at your account settings and see if anything is out of the ordinary.
AndyS007
Didn't work. I have tried the old 'power everything off and on' and see what happens.
It only does it in standby, as soon as I switch onto a channel it stops.
Hi there
It looks like a good ol'e factory reset is needed:
[Home] > Settings > System Settings > General Set-up > Factory Settings  (and follow on-screen instructions)
AndyS007
Andy
Hi there
Glad you managed to figure out what it was - wasnt aware you had a Sonos Soundbar - didnt even know it had an alarm feature either :slight_smile:
