Darker picture when using DVD player via HDMI lead
john.williams.007
I have a KDL40EX503 television and a  RDR-HXD890 DVD recorder.
When I play a recorded programe the picture becomes darker.
I try to change the picture settings using the options buttons but all this does is operate the DVD menu and I can't gain access to the television settings.
Can anyone advise me what to do thank you.
seboyad
I think you can custom modify the picture settings for each input, so you need to get into the options of your TV to adjust it for the DVD input. I must admit my HX's picture settings are pretty much the same as normal TV viewing.
Just temporarily put a cloth over the front of the DVD and use the TV remote to access the TV's settings 🙂
Hope that helps.
