How to Disable the sleep timer on my Sony Bravia KLD40EX503 with the remote control, annoyingly switches off every Two Hours.? Have looked and registered on Sony support and the Manual but to no avail.
Thanks for your help with this matter. ?
Yours Truly,
Dave T.
Message was edited by: Dave2840
Hi Dave,
Have you tried pressing the "OPTIONS" button on the remote and scrolling down to "Sleep Timer" and press ->. Scroll down to the bottom of the list of delay times and select 'Off' then OK.
If the OFF option is not shown, then the Sleep Timer is already turned off and the problem may be something else. You may want to look at the Presence Sensor timings and see if turning that off cures the problem.
Hello,
Have you checked the following thread
https://www.sony.co.uk/discussions/message/620763#620763
BR,
