DSL -S40A12U
Jasehill5
DSL -S40A12U
Hi all please help. My tv worked yesterday but not today. The red light is on in standby but nothing when you try to turn the tv on. Jason
Bravia55HX
i believe you mean KDL40A12U, the red stand by light does this appear to be flashing in a sequence at all ?, for example flash 3 times then pause then flash 3 times again?, if so then you will need to contact your local Sony authorised repair centre for repair.
Jasehill5
Hi, no the standby light is not flashing. It's just on as normal.
Bravia55HX
couple of things to try, unplug the tv from the mains and change remote batteries for fresh ones, if the tv still fails to come on then an engineer may be required.
