Can I browse any website though my tv, as I can only access the Sony website. Thanks
Solved! Go to Solution.
Press Options then scroll down to URL entry. It's a bit painful though and I don't think you can change the home page away from the Sony site.
As above but to make it less painful next time, when you first go on the site set-it as a bookmark if you are likely to go back. (press options, scroll down to add bookmark and select).
Message was edited by: Pete..
