I have recently purchased a Bravia KD43XE7073 (last week).
The only way I am able to access Freeview Play is by turning off the TV, disconnecting the mains lead, then turning the TV back on.
Is anyone else having this problem?
Hi Andy,
I would recommend getting in touch with Support here for further help with this.
Thanks,
Sean Mc
Thanks for your reply re Freeview Play
I have already contacted Sony Support. Case:16621885.
I have carried out all instructions given without resolving this issue.
From reading other forums on Freeview Play it appears I am not the only one experiencing this problem!
It is not a big problem to re-boot the TV when I want to use Freeview Play it's more of a "niggle".
Kind regards
Andrew Pink
Sean-Mc
Reply 2
Apparently this is a known problem. See below taken from using Google for: Freeview Play Problems
