HDMI Connection
harvey-r528
HDMI Connection
Can HDMI unput be sellected automatically. I have a Humax HD digital recorder connected to my Sony S series and I have to select HDMI input manually everyy time I swith on.
Thanks in advance for any replies.
Ray
profile.country.FR.title
ClarkLong
It does only if your player is HDMI CEC compliant.
If yes, then you can turn on th efeature on both your player AND TV
If not, then you have to play with ur remote everytime
harvey-r528
Thanks Clark,
I will set my Humax remote to operate TV and see if that makes any difference. I am sure that it is HDMI CEC compliant.
Regards,
Ray
