Home cinema
CHRIS-C.
Home cinema
Are there any rear speakers compatible with HT-G700 bar & sub?
LightFoot
Specialist
Hi @CHRIS-C.
I am sure that you have “googled” it but the consensus looks like “Because the HT-G700 lacks the wireless capabilities of Sony's pricier soundbars, it can't be upgraded to a full-on 5.1-channel system using a set of wireless surround speakers; in other words, what you see (and hear) is what you get.”
LightFoot
Specialist
Hi @CHRIS-C.
CHRIS-C.
Thanks for the reply. Frustrating but that’s life…. CC
