How do a change my "start-up input" from analogue to AV or HDMI?
profile.country.sv_SE.title
TequilaTT
Hey
I have a KDL-46EX710 and have a really annoying  problem. When I start my TV it always choses the analogue input but  since I have a digital reciver connected to the AV2-input I want it to  go straight to AV2 when I turn on the TV. It is really annoying to have  to mute the TV to avoid the noice from the analogue input (there is a  huge different in volume b/w analogue vs digital).
So, my question is basically, how do I change my "start-up input" from analogue to AV or HDMI?
Bravia55HX
firstly you posted this in the wrong place!,
go into menu-settings-set up-HDMI set up, and turn control for HDMI to on, then check the device list update and check the device (blu ray player) or such is being picked up.
cannot remember off hand but you may have to check HDMI control of each device.
i do know that if you turn blu ray player on it switches tv to HDMI 1,
Hope that helps.
