Anyone who know how i do this? I have updatet my TV, but there is no Netflix to be found anywhere.
Solved! Go to Solution.
Hi there
I'll referr you to the Netflix FAQ : http://community.sony.co.uk/t5/Televisions/Netflix-FAQ/m-p/373369
However, the short answer is that you need a TV model that is made in 2012 onwards. You have a 2011 TV.
If you need it, try looking at one of the newer Sony Smart Bluray players.
Hi there
Thank for the quick answer
I'll check out the link you sendt.
