How do I parental lock 'you tube'???
Lorraine6
I don't know if the answer to my question is staring me in the face but I can't seem to find it!!!  I want to lock you tube or the whole 'video' bit, so that my young children can't stumble upon things they shouldn't.  Any help would be appreciated. Thanks :slight_smile:
Lorraine6
Thanks for your help but we use our router for our internet as well......I will just have to make sure that I always have control of the remote :slight_smile:
Lorraine
6 REPLIES 6
profile.country.hr_HR.title
DamacizSi
I do not think that You can do that. You can just lock programs over parental lock.
R
Damac
Lorraine6
Thanks Damac,
I hope Sony take note of this and do something about it on new products, as you tube can be accessed 24/7 and has stuff on it that's alot worse than some of the channels I can lock??!!
Doesn't seem to make sense to me.
Thanks again
Lorraine
Meestar
Hi Lorraine,
Just a thought, but you could probably set up access restrictions on your router. Most usually have some form of setup for this, and often this allows this to be set up on a time basis, so you can restrict it until say 9.00pm
Might be a workaround?
DamacizSi
We will provide it to branch office and we will see. Thank You for Your feed back.
Regards
Damac
:slight_smile:
Lorraine6
Lorraine
Lorraine6
Lorraine
