How to install DIVX code in to Sony TV
mifrost77
Hello
I wonder if anyone knows how to actually install the DIVX software given now I have registered the Sony TV please?
Mick
Catmambo
Hi
I think that's just for 'DivX pro' files which basically don't exist anymore. Any regular divx file will play fine without registration. Best thing to do is just chuck one on a USB and give it a go.
4 REPLIES 4
Bravia55HX
as far as im aware you dont need to, your Bravia has DivX built in, just load your files from your computer onto a USB flash drive and your tv will play them.
mifrost77
Hi
Thanks for quick reply but I do have to register as I have been given a code to register on the DIVX website supposidly telling me how to register (TV is not registered)
Many thanks
Mick
Catmambo
Hi
mifrost77
Many thanks for that, all seems to work well!
Mick
