How to remove/eject a usb from Sony Bravia KDL-32W66OE
Rhea509
I recently purchased a Sony TV to view my tv series on usb. It plays great but there is nothing in the user guide to say how to eject/remove the usb2. I press Return then turn the power off, but when I insert the usb2 into my computer it tells me that there could be some errors on it, then it repairs it and states that no errors found.
I always remove usb correctly on my computer and never have that problem when I was using a media player on the old TV (which died on me).
Tags (0)
There's a troubleshoot article about using an external USB TV Hard Disk Drive here. Hopefully it will give you some ideas.
Rhea509
Many thanks for your reply. Read the link, but this refers to an external hard drive, not a usb memory stick. Tried this anyway but no luck. I do have a couple of external hard drives so might try these instead of the usb memory sticks.
