How to select startup source
nigglew
Just acquired a 40EX503 which has a PVR connected to AV1 but also has an aerial connection. On switching the TV on, it starts to show  a digital TV channel but after a few seconds moves to select AV1. It is then possible to manually select "TV" via the remote but I would prefer to have this remain on TV at startup until I wish to change it. Is there a setting I have missed?
slowtrain
Hi nigglew
Not too sure on this, perhaps the only way is to have the PVR turned off.
gentie
Did you find an answer as I have the same problem?
