how to unlock usb 40ex402 to let mkv
profile.country.sr_YU.title
zogaxhaker
Specifically posedjujem bravia lcd 40ex402 so I am interested in whether it is possible to unlock the aforementioned USB TV in order to play the MKV files.
pozz
Message was edited by: zogaxhaker
BlueSmoke1000
In this thread, I've written a guide on how to make MPEG files play on a Sony Bravia :
https://www.sony.co.uk/discussions/message/638254#638254
This will also work with mkv files, converting them into .m2ts files.  This doesn't affect the quality.
Hope this helps!
profile.country.hr_HR.title
DamacizSi
You can not. Mkv are not supported via usb. Find attached tabel of supported fails and formats with extensions for all models Bravia 2010.
Regards
Damac
BlueSmoke1000
Hope this helps!
