Hi One and All.
I am a registered user of a Bravia KDL37EX403 and would like to know before I buy, if a HT-CT60, which is on sale at my local Saisnbury's would work and link together correctly.
Regards
David
Solved! Go to Solution.
Hi there
I have looked at the specification of the soundbar to your TV, and can see no reason why it shouldn't work. To connect it up, you would use an optical cable from your TV (Digital Optical Out) to the soundbars (Digital Optical IN). The Optical cable should already be supplied in the box. Just remember to set the sound on the TV to output externally and set the input source on the soundbar to "optical"
http://pdf.crse.com/manuals/iManuals/egb/3a-2/asystem_aepga.html
and
http://pdf.crse.com/manuals/4435635231.pdf
Hi there
and
Trying to connect an HT-CT60 to an old Bravia TV that has no optical output. I bought a 3.5mm to 2 RCA plugs cable and connected it up to yellow and white outputs from the TV, but go nothing. I changed to analogue and con-ax options on handset, but still no joy. Any ideas?
should be Red/White for audio. Yellow is for video. Try that.
If not, can you reply back with the model of the TV as well.
