Hello,
Does the KDL-46NX723 allow IP control, for example using RoomieRemote via WiFi or Ethernet?
Regards
I check the specs on this. Seems like it does not have WLAN capability. This would mean that IP control won't be possible.
Hi west20 and welcome.
Have a look here for compatible IP Devices: -
http://www.roomieremote.com/ip-compatibility/
The HX and EX model TVs are listed but not the NX. I would guess this is an omission as the NX range is superior to the EX.
It will probably work OK, with the limitations listed but you may have to email Cyphersoft to check.
2011 and 2012 Sony Blu-Ray players appear to be supported also.
Another answer up to your usual standard mithcd! Of course this model has Ethernet and built in WLAN. What specifications are you looking at?
http://www.sony.co.uk/support/en/product/KDL-46NX723/specifications
Hello,
Just to put the record straight. The NX720 range is listed at roomieremote compatibility but, to my cost I have found this not to be competely reliable. Therefore needed to check.
Regards
