Is this a TV problem? I think it is.
Exit35
Sorry if this is the wrong board but my tv (Kd65xe8596) has recently started doing this:
Usually it clears itself up and I have no issues. Other times when this happens I change to a different HDMI and the TV will sometimes freeze then reboot. Just wondering if someone has had a similar problem. I bought the TV brand new in May last year, if its serious should I return it to curry's or contact Sony?
Thanks for any advice
Exit35
20190408_183501.jpgToday my tv boots up and I'm greeted with some horrible green bars, when actually disappear when my xbox is switched on. Is this an indication my tv might be dieing?
Mick_D
Moderator
Hi @Exit35, welcome to the Community.
With so little remaining on your warranty, I wouldn't wait much longer before getting it back to Sony to get it checked out.
You can book a repair here.
Best wishes
Mick
Exit35
Thanks for the response. I actually bought my tv from curry's, so should I contact them? I came here after a Google search.
