KD49XF7002 49 Ghosting.
Madmonk
I have had a Sony Bravia KD49XF7002 49 for just over a year and I am getting Ghosting on the screen on the left side and the bottom. Seems to be getting worse, was wondering if anyone has this problem. Any advice welcome. Thank you
Peter_S.
Genius
Hi Madmonkey,
Usually this shouldn't happen except some force has been put on the frame.
I would suggest to get in touch with support as long as you're within warranty.
Peter
