kdl-32ex0703 and DNLA - what video file types can it display?
stuspa
Hi
Does anyone know what kind of Video file types the
kdl-32ex0703  Bravia TV will run?
I want to connect a synologoy 215+play NAS server to the Bravia TV, and hopefulyl run KV video files.
Can the kdl-32ex0703 do that ?
Thanks in advance for any help.
Stu
stuspa
I meant to type
MKV files.
Not KV files!
Hi there
Just to clarrify, your TV model = KDL-32EX703
Unfortunatley this TV doesnot support many files via DLNA (see supported files below).  However, if you install Serviio through the Synology's DiskStation Manager, and enable 'transcoding' - the synology/serviio will proceess and convert the file 'on-the-fly' to play those files that are not supported.
See:
http://pcloadletter.co.uk/2012/01/25/serviio-syno-package/
stuspa
hi - thanks for the reply
yes thats the model
i know its a bit old
have had some success streaming from VUZE which is installed on my mac across the network.
But was hoping to get a NAS that I could do backups onto and keep all my video files + play from it.
I'll have a look at the link you sent me
thanks agains
stu
