KDL-40HX700
profile.country.el_GR.title
8722086081
KDL-40HX700
i have a usb stick and i see some converted movies   in avi format, some movies of them  play and some they don't. i must put codecs to tv????
profile.country.hr_HR.title
DamacizSi
Find attached tabel of supported formats with extension via usb on Bravia and there You can see that .avi is good in Divx over usb but complated with Divx Home Theatre 3.0
http://www.divx.com/en/partner/certified/ic
Regards
Damac
:slight_smile:
DamacizSi
Regards
Damac
:slight_smile:
