My new Sony TV will not work when the aerial is directly plugged into it but will when connected to my BT box, which is connected to the aerial. Does any body know why?
Also when I try to get BBC One HD it shuts down after some time and a message appears that lasts for 5 minute, which reads " HD cannot yet show programmes from your area". The message then disappears. How do I know if I M HD or not ?
sounds like this TV has been purchased from abroad- where did you buy it from? does the serial number in back of TV match with the TV boxes serial number?
You may have to change the power settings of the TV
