KDL-40W5810
KDL-40W5810
i HAVE HAD THIS tv FOR SOME TIME AND i AM VERY PLEASED WITH IT, I AM TRYING TO LOACE ANY UPDATES FOR THE KDL-40W5810 WITHOUT SUCCESS, AS THE tv IS GETTING ON A BIT ARE ANY AVAILABLE?
I AM ON 1.74OSA OR IS IT 1.710SA
Hi there
As far as i can tell, there are no furthur updates to your TV.  Unless a major fault occurs on many of the same/similar models, an update will no longer happen.
