Hey.
I want to buy a new TV, but it should hang on the wall. I know that sony's w9 series has standard VESA mounting points. In addition, I know that there have been problems with their w6 series and they do not have VESA mounting points.
There has however been made some wallmounts for them:
http://www.av4home.co.uk/blog/guides/wall-mounting-a-new-sony-kdl-w6-series-tv/
My question is:
Do the w8 series have VESA and if not then what?
Do you know how i can wallmount it?
Hi there
I believe it has the VESA holes, but I cannot confirm from the Sony documents (spec and manual). Googling it brings up retailers saying that it is. The best thing to do, is before purchasing it, go down to your local retailers, and ask them there, and even view the back of the TV itself and look for the VESA screw holes.
