KDL-42W805A
KDL-42W805A
i have purchased a Sony sound bar for the Bravia but I have lost the bottom part of the screen as the sound bar hides it. Can i purchase a taller stand to raise up the TV? TY
Hi, It is the TV i need to raise up.
The TV stand is made up of an oval base with a plastic cylinder that the TV attaches to. I need a taller cylinder to raise the TV above the height of the soundbar.
TY
Hi there
Unfortunately you cannot modify the stand on the tv to make it higher.  Therefore you need an alternative way of doing things.
Such as:
  • Adding a bracket to the back of the TV, for the soundbar to go above the TV.  See : HERE
  • Adding a TV riser (like a box) underneath the TV.  Google "TV Riser" for products.
  • Table top stand.  Seach Amazon for "VESA Table Top Stand" for compatible products
