KDL-52X3500 TV
herolegend
KDL-52X3500 TV
ok so I got this tv over a year ago now and never really used this port on the tv was wondering what it was for exactly it says pc card at that back of the panel slot when i pull the plastic bit out what is this PC CAM card thing? what can I buy to get it to work?
5 REPLIES 5
Catmambo
Its a CAM slot (Conditional Access Module) so you could add a Top Up TV card to the TV if you wanted..
thanks
herolegend
thanks for reply what exactly can you get from this top up tv card? and is it expensive?
slowtrain
Hi herolegend
You can get all the info from here
slowtrain
herolegend
oh cool thanks
petdunn38
I would not advise buying a CAM card for TopupTv (ESPN). I have had a  CAM card for a number of years and it worked fine until Oct this year when it stopped working due to a problem with the uploads allowing viewing. TopupTv claim no responsibility for this and say it is down to Sony to resolve. I have asked Sony for their comments on this issue.
