KDL40R553C radio problem
El-dee
My TV switches off after about 12 minutes of listening to radio on channel 704. I can't find a setting that might be doing this. It doesn't do it on TV channels.
Hi there
Have a look at the ECO options in the Settings Menu.  Especially "Idle TV Standby".  Also helps to disable Power Save settings too.
El-dee
Thanks. I'll give that a try.
