KDL42W653 & SideView
bergipau
Hi
I have a KDL42W653 which I am very happy with. I downloaded TVSideView on my Samsung Galaxy S3 and it is not working. I can use the remote on my phone but the screen mirroring is not working.
I also tried on a sony phone and I am having the same problem. I believe the problem might be my wifi router. Can anyone verify this? also, if I wanted to replace router what do does it need to support to allow this app to work correctly?
Regards
Paul
pennbank
Have you read
http://community.sony.co.uk/t5/Televisions/screen-mirroring-KDL-42W654/td-p/1254888
The display of a Miracast supported device (eg some models of Xperia) can be mirrored wirelessly
http://www.wi-fi.org/wi-fi-certified-miracast%E2%84%A2
Edited: Put the 3 posts together.
bergipau
Got it working, thanks. I was trying you use the the sony app, but I should have used android AllShare Cast.
