MediaRemote compatibility KDL-40NX713
nigelmansley
Are there any plans to upgrade the firmware on the KDL-40NX713 to allow compatibility with the MediaRemote app?
Tags (2)
Catmambo
Hi, unfortunately not I'm afraid. The TV can't support it regrettably.
Catmambo
