- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Why some movies cannot be played on bravia kdl-32ex650? all movies its AVI file and some movies can be played and some cannot...
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Im not sure how to actually explain this, but....
AVI is just a container, where you can use different encoding codecs, but still be under the AVI container. Some of the codecs may be supported by your TV, and others cannot.
I would recommend you either converting the files to a format your TV recognises, or use a piece of software called Homestream (or Serviio). Homestream is Sony's answer to the various file formats/codecs available, which is based on the Serviio software.
http://www.sony.co.uk/hub/1237485339460
Hope that helps in any way.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thanks again, i just convert movie over aviaddxsub software to divx file and its works
