my bravia 32w670a tv failed wifi direct with my 4.4.2smartphone
profile.country.IE.title
Rony_Hassan
I have successfully connected wifi direct with my phone earlier.but now it fails.I tried manual and only manage to connect using "other" ssid and pin where in device list shows unsupported wifi direct dev accepted.
in my phone wifi-direct setting I can see my tv.tap to connect but no connection establish.
another thing...when my device was successfully connected and I sent picture result sending failed.
please show pity for my poor english..hope you understand my problem..thanks!
Rony_Hassan
after performing a power reset things working for me!
1.power off with remote
2.remove tv power cable/cord from outlet for 2 minutes
3.plug the power cable to outlet and turn tv on with remote
this reset works with most error!
thank you...
Mick_D
Moderator
Hi Rony, you may have to delete from the list and start again. Have a look at these instructions for screen mirroring, hopefully that will get it working for you https://bit.ly/2JoRTvP ^Mick
Rony_Hassan
Thank you for replay...yes I found and deleted one device from the screen mirror list.and still I cant connect wifi direct with my device.. in tv wifi direct list is empty.I can only connect wifi direct setting>manual >"other" by imputing wifi pass shown in tv which is not wifi direct..
I updated my tv software today..I can see my tv in my mobile wifi direct setting..
Rony_Hassan
thank you...
