Netflix not available on Sony Bravia KDL-32CX523
akis01
I have just discovered that there is no Netflix option on my Sony Bravia KDL-32CX523. We bought it March 2012 (I think). Is there any way we can watch netflix natively on it or do we need to go through an external device?
Akis
4 REPLIES 4
Batfinkk
unfortunately its not available on that device. Its on all their new Blu-ray players seemingly http://www.sony.co.uk/hub/blu-ray-disc-player
akis01
Will it ever be available though?
Hi there
Simply put, device models that are PRE-2012 will not get Netflix. There are technical reasons for this (if you want to know more, use the search facility on these forums). However, I will point you to this FAQ -
https://www.sony.co.uk/discussions/message/1265664
Hope that helps.
(NOTE: I can understand your frustration, as I was annoyed too when it was announced. I too have a 2011 model tv)
orkneymiss
I have the Sony Bravia KDL-46EX524   I was having the same problem in the UK so I bought the £30 Google Chromecast and it has solved the problem with Netflix. A great gadget and easy to install and use. http://tinyurl.com/oew36pu
