Panel Problem with 65xe7096
alprio
Hello,
4 days ago i purchased the tv on the title,from a big local store in greece..
Today i saw in white background something like "dirt" inside the panel.The "dirt" is permanent and it appears at all colors/images.
I tried to clean it outside but i couldnt. It is inside the panel.
Also i found 5 to 6 dead pixels. Not all together though.
I will attach some photos with the "dirt". If it is dirt. Should i return it to local store or contact with sony.
I tried to find an email for sony greece but i couldnt.
Thank you.
https://1drv.ms/f/s!ApQ0myF2tm7DjK4tQMiI6dCCkCRziQ
Pascale_F
Moderator
Hi alprio,
Welcome to the community.
I'll see if I can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
