panel
ilektronio12
panel
Hello.
Entering the service mode, I changed the model of the panel. Since then the TV has no picture.
There is a way to fix this.
Thanks.
KDL-40R470A.
5 REPLIES 5
royabrown2
Hero
@ilektronio12
You had better hope that a Factory Reset will bring your ten-year-old, non-UK, TV back.
Such menus are for service engineers with tools, equipment and training, not for the likes of you and me 😢
Piscie
Community Team
Hey @ilektronio12, you can try a forced reset as a last-ditch attempt to fix it, and hope it works!
ilektronio12
Hello.
Thanks for the answer, but as I said, the TV has no picture. How to reset it?
Piscie
Community Team
@ilektronio12, the link illustrates how to perform the forced reset using the TV buttons, not the TV settings. If that doesn't help, I'd recommend contacting Sony directly to see if the TV can still be repaired at their service centre.
ilektronio12
Hello.
Finally, I found the service manual and on the service mode page, I measured the movements needed to go to the panel settings, I did them blindly, and the TV came back on.
Thanks.😁
