PC to TV via VGA
BOGGIE2
PC to TV via VGA
I'm trying to connect my laptop to my Bravia TV using a VGA to VGA cable. My laptop knows something is going on but the PC tab in the TV menu is still greyed out. Can anyone help?
Message was edited by: BOGGIE2
wetsleet
most laptops will have a key to toggle between laptop/external/both screen outputs.
You might also have to go to control panel/display and mess with the settings.
profile.country.hr_HR.title
DamacizSi
http://support.sony-europe.com/tutorials/tvhc/computer2tv/computer2tv.aspx?site=odw_en_GB&m=KDL-40EX...
Klick on Your typ of grafic card on link, scroll down and follow proper connections step. For sound use 3,5 mm audio chinch from pc to tv.
:slight_smile:
