Play external subtitles - MKV movies - KD65X8505BBU
icemintb
Dear All,
how can i play external subtitles with mkv movies? i'm using WD Cloud. i have tried using the .srt subtitle in the same movie folder and with same name... but apparently its not working. 😞
please advise
kind regards
Hi there
You cannot use .srt files via DLNA.  You will need to install a DLNA Media Server such as Twonky.
See:
http://community.wd.com/t5/WD-My-Cloud/WD-My-Cloud-doesn-t-supprt-srt-file/td-p/670009
Search/post on the WD forums for more information:
http://community.wd.com/t5/WD-My-Cloud/bd-p/mycloud
Sebek74
Mux your srt subs quickly into MKV file using MKVToolnix. You will be able to change subtitles using remote control playing content via DLNA.
