Re: Remote Control Problem (RM-ED035)
cmacneil
 Hi folks
I have a similar problem (I'm not sure how to start a new topic here!!)
I have an RM-ED035 and Sony Bravia KDL-32EX403.  Both were new to me when I bought them some 7 years ago 🙂
Recently the remote failed.  I have checked batteries and general condition / cleanliness of the device.  All ok.
We have been activating the TV, channels and volume with the buttons on the right of the unit. However we'd really like to get the remote working again.
I've been on several threads which have suggested settings verification.  None of these options worked.
I then opted to factory re-set the TV.  I'm on step 3 of 13, which is asking for a PIN.  I don't need a parental control PIN now, but without the remote working, I am not sure how to over-ride this step, so the TV is not usable at all at the moment...!
Any thoughts to:
a/ override (or progress through) the set up without using the remote, and
b/ getting the remote back to working condition?
Many thanks,
Chris
Hi there
To create a new topic, all you have to do is go to the subject you need (i.e Television) and click the big blue 'New Message' button.
If your remote control has failed completely, there us probably not much we can advise except buying a new remote.
In the mean time - see if any of the tv buttons help.
http://pdf.crse.com/manuals/iManuals/egb/3a-2/tvcright_aep_ga.html
cmacneil
That's great thanks!
Chris
