recording is not working on kdl- 32wd600
profile.country.RO.title
eugen35
i have a sony bravia kdl-32 wd600 and i have a usb disk 64GB and i put it in usb and works register to tv and i try to record something on it from tv works but when i try to open the file i recorded it says recording it`s not available and has 0h 00m so itdoesn`t records any thing . I have the same problem with a hdd external 256GB can someone help me?
EdwinaU
Moderator
Hi Eugen,
Welcome to the community.
Have you used this USB drive and HDD with this TV before? If not, they may not be compatible with your TV, you can check to see what is supported here
Best wishes,
Ed
