Removing Info Banner from xe70 tv
andybarratt2650
I just got a 49" XE70 TV.
Is there a way to fully disable the info banner? Every time I change the channel on my YouView box, I get the infobanner appearing at the top, but I don't see an option to disable it.
I'm sure there's the option to disable it on my slightly older Sony TV.
andybarratt2650
I discovered the solution.
The problem was with my HT NT-5 soundbar. I had to turn some settings off on that.
4 REPLIES 4
cass_n
Community Team
Hi @andybarratt2650 - I've checked this for you and it's not possible to disable the info banner on that particular model I'm afraid.
andybarratt2650
dozer75
I know this is an old post, but what settings did you have to turn off on the HT NT-5 soundbar? Struggeling with the same issues and would like to check if it is the same.
andybarratt2650
Struggling to remember to be honest - sorry
