Setting a program reminder on Youview
Just bought a Sony Bravia KD55XG81 55-inch LED 4K HDR Ultra Smart Android TV and can’t seem to set a programme reminder on Youview - can anyone help as can’t imagine why this function wouldn’t be available??
Thanks!!
Sony BRAVIA KD55XG81 55-inch LED 4K HDR Ultra HD Smart Android TV with voice remote - Black (2019 model)
4 REPLIES 4
Pascale_F
Moderator
Hi Robbie,
Welcome to the community. I'll just see if I can track down some info. Maybe someone else in the community has an idea in the meantime though.
Thanks,
Pascale
Win_88
Specialist
Hi Robbie,
As far as I'm aware, this functionality isn't available when Youview is enabled on the TV. This was raised to Sony as feedback.
Win_88
Woody1001
Just bought the Sony AG9 65” and I am amazed that YouView doesn’t have that functionality so have to switch back to standard viewing but now can’t use the itv hub app as it says I have to enable YouView 😳😳😳
Julesrann
There is a permissions issue between you view and Sont, so as a result not all functionality is available, so like me you have a TV which you can fully use.  Very frustrating as it’s not a widely publicised issue
