Sky wifi won't connect to Sony tv KDL 49WD756
profile.country.IE.title
lynchp4
I've been trying to connect to the wifi for hours but failing
I can find my sky on the list, put in the EPA code and then connect
then is says
 Wireless device on tv - found
local access - failed
internet access - failed
ive Restarted factory settings, plugged out the tv and the sky q router, tried scanning and pushing Wps button
its not the first time it's happened but this time I just can't fix it. The wifi is working fine on my mobile and the other Tvs - it's always just this tv! Is it faulty? I only have it a few months
cass_n
Community Team
Hi @lynchp4 and welcome to the community,
Thanks for the info.  I recommend getting in touch with Support so that they can assist you with this issue (details here).
Cheers,
Cass
